Re: tachometer on a honda bf40
For the 1999 BF50, did the tach ever give the correct readings? If the tach just started giving you a problem, may times it is related to a poor ground somewhere. Try cleaning the terminal wires on the back of the tach to start. A tach runs off your alternator which and associated rectifier and voltage regulator. There could be a problem there. Or you could have a tach that has gone bad and needs to be replaced. Not really familiar with a tach that does not have a selector dial on the back which allows you to change the alternator pole setting.
