jpwilly
- Jun 15, 2011
- 95
Hello iBoat Force Forum! My name is Joel and I have a Force Outboard - :lol:
I have a new to me 1994 Bayliner Capri 1700LS with the Mercury Force 120 (serial # OE0493XX). Boat and Engine appear to have been built in 1993 sold as a 94. Tach / RPM gauge isn't working. When run power is off needle is straight down and when power is switched on the needle moves to zero. When cranking or running needle doesn't move off of zero.
I've looked behind the dash and checked the wires are all connected correctly and tight.
I've moved the arrow between the different settings and back to the #4 and checked to see if I have a 20pole or 12pole (it's 12).
I've removed the cowl and looked at the regulator / rectifier. Looks like an aftermarket unit with two yellow, one red, and one grey. All are connected up properly.
I don't know if I have a battery charging issue or not
I have the Black Stator not the newer Red one but it looks good no goo or burn marks.
Is there something I can hook up to the signal wire (other than my tach) to see if it's pulsing?
Or what other simple testing can I do to determine if I have a bad regulator / rectifier
I don't have a shop manual and figured I could download a free PDF somewhere but haven't found one. Anyone have a link or care to share?
Thanks for helping in advance - Best,
Joel
Joel
