MN-WaterGuy
- Aug 6, 2011
- 22
Last year, I bought a 16' 1989 Smokercraft with a 1989 Mariner 45hp. Very low hours on outboard, and after getting some bugs worked out, it runs like a top. The prop is factory aluminum. With a half tank of fuel and no passengers, I can get about 27 mph (via gps) on a calm day. I would like to eek out a little more performance, and I think a prop change may do the trick. Unfortunately, there is no tach on the boat. I've poked around the site quite a bit, and it's pretty obvious that prop changes are crapshoots unless you have a tach and can figure out WOT rpm's. I'm looking for advice on the best route to take regarding a tach. I have no specific make or model in mind. I just need something to give me accurate rpm readings. Any advice is greatly appreciated.
