tachometer for anything
coolguy147
Digital Hour Meter Tachometer Tach Tacho for Yamaha KTM Honda Kawasaki BMW Motorcycle Dirt Bike ATV UTV Quad Generator MX Snowmobile Boat Outboard Jet Ski 4 2 Stroke Gas Engine : Amazon.com : Automotive
Cheaper version of the tiny tach?
I had a tiny tach but it stopped working all of a sudden and would lock up when it read readings for my old mercury. Wouldn't read anything right. The place claimed it was the wires that shorted out the unit but they look fine. The battery is probably dead by now.
Anyways, I need a tach.
bonz_d
Re: tachometer for anything
Looks interesting! Are you going to try one?
bonz_d
So are you saying that they carry these at Northen Tool also?
I have a Faria tach that I couldn't get to work with my 35hp Rude but maybe it will work with the 50hp Johnson.
Again if you try one LMK what you think. I need to find a tach to dial in a prop on this 50hp.
Willyclay
Sea Rider
Some hour tachs don't work well in all outboards unless they have spark firing timing. If this model doesn't have it, specify engine model when ordering. Electronic specialist models are for larger applications, workshops, etc and do cost more..
Must be one of a kind, have a Tiny Tach bought and installed in 1997 with 900 metered hours and still runs as a champ. The new TT-2A is a superb tach.
Happy Boating
Willyclay
Buy Electronic Specialties EZ Tach Plus ESI328 at Advance Auto Parts
Advance auto carries it too. How strong is the wireless signal? Can I drive the boat and look at this at the same time? Or will someone have to be 3 feet away from the engine? How long is the wire?
The wireless signal requires the handheld unit to be within one inch of either a spark plug wire or an ignition coil wire. The inductive pickup wire is 36 inches long. If you want a permanent installation in your boat, this is not what you want. If you want a portable tachometer for checking all your outboard motors, motorized lawn equipment, cars, etc.; then I can recommend the ES328+. Good luck!
coolguy147
Yea, it won't reach the steering wheel lol. I don't want it as a permanent installation because i would also use it on my atv, or any other outboard i might own in the future.
Will this work on old magneto style ignition systems?
As long as it's a good working tach that doesn't give me problems, i'm ok with that.
Sea Rider
If you want a tach just for reading max rpm at wot, testing different pitch props, setting idle speed, etc a TT is the way to go, wire is long, don't know if long enough for your engine/helm distance. But a buddy near engine could hold it and check tach's rpm. TT-2A being firing programmable could be set to match different engine firings and that's a + to have.
Happy Boating
coolguy147
Happy Boating
The tiny tach would give me flawed readings for my old magneto system outboards. I have a tiny tach. It broke within a few months use. That or the battery died prematurely.
EDIT: Btw, the EZ tach plus is only sold online at advance auto.
MattFL
Master Chief Petty Officer
I've had several of those little sealed tach's made by SenDec and they have been great. I've used them on several generators, my boat (Honda 50HP) and I Just bought this one for my new Tohatsu outboard:
Hardline Products HR-8061-2 Hour/Tachometer with adjustable input, Resettable MAX RPM and Log Book : Amazon.com : Automotive
It remembers total hours, number of starts, peak RPM (you can reset this to 0) and it shows you the current RPM. I mounted it under the hood and just check the peak RPM and total hours. It's sealed, so no worries about it getting wet. Some motors fire the spark plug every revolution, and some 2x per revolution, and I believe this one is adjustable. The default settings worked fine for me.
