blueoval78
- Jul 19, 2010
- 43
I just installed a Faria tachometer on my 1988 Force 50HP outboard. When I turn the ignition key to on, the needle slowly starts climbing and when I start the engine it climbs past 7000RPM and stays pegged at it's maximum position. I specifically selected a 20 pole tachometer from Great Lakes Skipper. I hooked up the purple wire on the motor that said tachometer to the signal post on the back of the tach. I then got power for the light and gauge from the instrumentation wire in the dash of my boat. (Both are feeding from the same power) I grounded the gauge to the same ground as the instrumentation.
Any ideas why the tach is acting funny?
