Re: Tach Wiring
If you hahve a OMC control box with a rubber electrical type plug just under the ignition switch, there will be three sockets there. With a ohm meter you can find which sockets are the Ground (G), voltage of 12v (I) when the key is ON, and the remaining one would be the sensor unit (S).<br /><br />If you do not have this setup, look for a Gray wire leading from the instrument wiring harness, that is the harness leading back to the engine. That Gray wire is connected to the rectifier at the engine and is the sensor unit (S). The other two.... 12v (I) when the key is ON and the ground (G) would be self explanatory.<br /><br />--------------------
