Re: Tach & Speedo ?
bucksaw, <br />does your throttle control have a black cap on the forward bottom end. If it does this cap covers the tach hookups. There should be three (3)places to plugint under the cap 1 is 12 volt power (white). 1 is negative (black) and 1 is for the tack negative connection (brown). these are in side your control and unless you take it apart you wont see them, I used a ohm meter to trace them down. I got my tach from my local NAPA dealer (pro tach) 3" can be mounted in the supplied bracket or in dash.(about 34.00) On the tach the red wire hooked to 12 power, the black wire to ground and yellow to the negative side of the ciol (brown). you might be able to find the proper harness at you local merc dealer. Hope this helps.
