nmhellraiser
- Jun 16, 2007
- 120
Alright, I've got a Marpac tach on my boat that I can't get to work properly and need some info. I'm pretty good with wiring but want second opinions. I've got a 1983 johnson v4 140hp on the back of the boat. I've got my gray wire from the harness tied to the signal terminal on the tach and I've got my positive and negative to the respected terminals. I've set my pointer on the back of the tach to 6 and the tach doesn't seem to work. I can change it to 5 and it works when it wants. Same thing when I switch it to 4 but as I go down with the numbers the rpm's raise to numbers I know aren't correct. What am I missing? It should be set on 6 correct? I haven't checked the exact voltage with my meter but I'm getting constant power on the gray wire. I'm just using a test light to verify voltage.
