I was checking to see of my tach was set to the proper engine size the other day. When I removed the tach there was a rubber plug in the back that covered the hole for the "number of cylinders" switch, when I looked inside the hole there is no pointer or dial to turn, it looks like there should be one, but there is not. The tach is a quicksilver brand, and seems to work fine, however when the key is off the tach reads 2100 RPM, it returns to zero when you start the motor. I am trying to determine the correct prop size and every prop I use over revs the motor. The boat is an 18' aluminum center consol flat bottom with a 100 hp mariner.
