Re: tach question for a 1998 nissan 25c3
Well, I promised I'd post the results of my Teleflex tach and TSU testing, and I found that connecting the yellow wire from the alternator to ground does indeed allow the tach to work. However, that is true only up to about 2000 RPM. Beyond that, the tach begins to read approximately double what it should. I have a Tiny Tach which is very accurate that I used for verification, plus you can tell just by the sound of the motor that it wasn't running at the displayed RPMs. I did try changing the pole selector dial, but then it's wrong right from idle. I also hooked it up without the TSU in line, just to see if it made a difference and it really didn't. The only thing the TSU seemed to improve was that it eliminated a tiny bit of needle fluctuation with the tach reading. Then just to be sure there wasn't something else in the electrical system causing interference, I disconnected all other external electrical and ran a separate temporary circuit with only the tach, tsu and battery on it. So, it seems to me that I'm out of options for using my Teleflex tach with this outboard's factory tach leads. Any suggestions?
