I have a 70HP Chrysler and I had to replace the tach. I bought a Teleflex Tach with my motor listed. With the ignition off, the needle will sit anywhere from 200 - 400rpm's (says needle can sit anywhere when off). When I turn the ignition on, the needle goes to zero. When I turn the motor over, it will fast idle at about 1000 rpm's and normal idle at about 650 - 700 rpm's. So far so good!!!<br /><br />Now when I throttle up, the tach will not indicate over 1800 rpm's at WOT. I can only guess that my boat is going about 25mph. The instructions indicate that the setting on the rear of the tach should be pointed at 6P and that's where it is.<br /><br />I'm new to boating so I can't tell you what 1800 or 4500 rpm's sounds like on a 70hp outboard. The motor doesn't sound like it's racing high and it runs very smooth. I can't imagine that a boat weighing around 2000lbs would go 25 mph at only 1800rpm's.<br /><br />Any help or suggestions would be much appreciated.<br /><br />Thanks for your time,<br /><br />Dymo
