Tach not working
Jon Mutiger
Hi there, I'm about to buy a boat with a bf40, about a 2005. The boat and motor appear to be in great shape but the tach isn't working.
I'm mechanically inclined and have a multi meter. I'm guessing the guage needs power, ground and a trigger signal. Can someone explain to me how the factory Honda tach is meant to work so I can try to diagnose what's wrong?
Thanks,
Jon
Sea Rider
Welcome to Iboats,
Tach works with signal cable coming from OB, power & ground, check if tach has pulse selector at rear. Probably not set correctly ?
Happy Boating
Jon Mutiger
Is the pulse signal a digital signal or variable voltage? If it's digital I won't be able to use the meter effectively.
hondam
Neither it is an analog signal, the tachometer measures the frequency of the analog signal coming from the motor and cannot be reliably measured with a standard DVM. The voltage may vary slightly but is not the measurement the tachometer is taking.
The tachometer runs off the the charging system, if your charging system is operating properly then its probably the gauge.
