Re: Tach installation question
Before you get carried away with that..<br /><br />check inside the controller, you might find a grey wire floating around in there that isnt' hooked up to anything.. if so, then you already have a tacho feed wire..<br /><br />Its a 70HP and its late 70's, I'd almost bet money that it already has a tach pickup in the controller.<br /><br />What I mean by this, you can pick up a normal tach and hook up to the grey wire in the controller.. <br />I have telleflex tacho, hooked up to an older 100HP johnson.. and there was no running wires from the motor to the controls to do it..<br /><br />my tacho (whole dash actually) came from this guy:<br />
kv-e<br /><br />rgds<br /><br />Franki
