horsefly38425
Thread starter- Joined
- Mar 8, 2003
- 204
i have a stewart-warner tach i want to hook up on my 55hp bearcat 68-72yr model but were would the send wire be on my motor. my tach has 5 settings for 4-20 -none pole how do you find out what pole my motor is i ck it on ground side of the dist. but readings did not look right also have new oil and water lights for the ones that came in the org. swicth panel had been removed but there is only 1 wire that comes from both send units and i can't get lights to work right / should they come on with switch on & motor not running? really
