Re: tach help, and pressure gauge
There is only one way to add a water pressure gauge. 1) buy the gauge. 2) Install the head in the dash. 3) route the tubing from the engine to the gauge/ 4) connect the tube at the gauge. 5) install the fitting in the engine and connect the tube. 5) Connect the gauge light to the feed for the other lights. Your done. As for the tach, make sure the "sense" wire is connected. If the gauge zeros when turning the key on, it's probably ok, just missing the input.
