volvo, aq200c, 305 motor with points ignition. recently changed the shifter cable. since that time when i turn the ignition switch to the on position the tach pegs the needle and i get no spark.<br /><br />do i have a bad or broken connection off the coil or distributor? i am thinking that it should be in this area but can find nothing out of the ordinary.<br /><br />can you point me in the right direction?<br /><br />thanks
