Tach cutting on and off
Starr MUrray
I have a 1991 Evinrude 88hp with a teleflex tachometer. Here is the problem. It keeps cutting on and off the entire time the boat is running. It has to be a bad connection somewhere it ran fine two months ago. I checked the wires from the tach to the control box plug in, they are fine. What's the next step in troubleshooting the problem? Do I break into the control box or start looking under the cowling. The tach is fairly new could that be going bad?
chuckz
Re: Tach cutting on and off
Intermitttent problems are the hardest to fine. You need to find out if you have a power problem or a signal problem. Connect a voltmeter to the power input to the gauge, at the gauge. Check and see if the voltage varies as the tach cut in and out. If not, switch the meter to AC and connect to the signal input at the tach. If the voltage drops in and out you have a signal problem. Now you know which connection to troubleshoot.<br /><br />For this testing an old analog meter would actually work better than a digital meter. If you can find a Simpson 260 VOM use that.
Starr MUrray
Thanks, I'll try to find a volt meter from someone tonight.
mikebc
Mine did the same in a 1987, it was the tach.
