Hi,
I have a Merc 650 (serial 1690905 circa 1964) on a 15foot fiberglass hull. It currently has a two blade prop, which I would like to replace with a 3 blade (better for tubing/water skiing).
In the Seloc manual it states that WOT on the engine should run between 4800 and 5200 RPM. I am looking for a prop that will allow the engine to run at about 5000 RPM. The boat does have a tach but it looks like it is disconnected (no wires are running to the engine from the gauge).
I assume that it must be connected to the distributor/magneto in some manner to measure the pulses per second, but I don't know where.
Any suggestions would be appreciated. The service guide I have states that most shift boxes have a connector on the front for a tach connection, but mine, based on it's age does not seem to have one.
Thanks for any/all suggestions.
