Tac
ed3694
Can someone tell me if the Tac wire from the motor runs into the ignition before going to the Tac on a1989 mariner 200l
Texasmark
On other engines the tach (grey wire) comes off the voltage regulator/rectifier module.....(uses the alternating sinewaves to count rpms). It goes directly to the tach rear terminal labeled grey, or signal, or S or something other than 12v, Ground, ground symbol or lamp or something like that.
I don't know why Merc would design a different source for that engine per se. Difference in the modules would be due to increased amperage capacity for larger engines, but no reason to source the tach signal from a different point since this one works just fine.
