CaptainPuget
- Sep 29, 2002
- 137
I recently noticed that my tilt/trim motor is badly corroded. All the paint is gone from the body of the motor and instead of black it is a solid rust brown color with bits of rust flaking off. From the description and diagrams in my manual I can't tell if the motor and the pump are a single unit or if I can remove the motor section without opening up the hydraulics. In any event I'd like to stop the corrosion before it eats through the motor housing and ruins the motor. I'm not sure if I should remove the unit or try to treat it in place. <br /><br />Advice?<br /><br />1985 - Mercury 115hp.
