Hello all. I was checking adjustments on my Qd23. Things look pretty good but I have a question that I can't find an answer to in my manual.
The twist grip gets tight as it gets to full throttle and I have discovered the reason. When the carburator is open fully there is still an inch to go on the timing cam so the cam digs into the rubber cam follower to get to the stop.
Is this correct or should (can) the cam be adjusted for more clearance. Can the cam be moved and still be correctly synced?
Thanks, Greg
Thanks, Greg
