sx outdrive question
cbjones
I hit a stump and bent my prop this weekend. Well it was only slightly bent so i replaced it but I think I might have bent my prop shaft. can you remove the shaft with out taking the whole out drive off? Im really mechanically inclined so is this something I can tackle or will I need special tools?
Ayuh,.... Welcome Aboard,.... Check the end for run-out, before ya take anything apart,...
cbjones
sorry for not knowing terminology but what is run out? and how do you check it?
Pesimist
Clamp a micrometer gage to the lower gearcase, position it so the micrometer pickup is touching the prop shaft so you can check the prop shaft run out to see if it's bent as it it rotated.
Sparkinator
Call around. I bent my prop shaft a couple of years ago, and a local repair shop straightened mine. I think it was 150 bucks. That SX drive is built so solid, that they straighten the shaft without having to pull it.
