SX-A Top Cover Clearance
skydiveD30571
Trying to find the correct clearance for the top cover of my SX-A. The OEM service manual says "make sure correct shims are under cover" with no mention of what the correct shims are. I saw a different thread with clearance numbers for an SX drive but I'm not sure if it's identical.
Don S
Re: SX-A Top Cover Clearance
Using the picture below.
1. Measure in inches, depth of bearing seat in top cover. Save as measurement D.
2. Measure in inches, height of installed bearing above gear housing. Save as measurement E.
3. Subtract E from D. Add 0.005” to determine shim thickness.
skydiveD30571
How do I measure those with enough accuracy so that .005" makes a difference?
Don S
Depth Micrometer
skydiveD30571
Looks like an expensive one-time tool. Out of curiosity, if someone measured the clearance wrong and used the incorrect shims, what are the obvious signs? Noise, vibration, etc?
skydiveD30571
I found a couple mechanical ones in the ~$50 range. From experience, is there anything wrong with using one of these? They are new with 0-4" range and .001" resolution.
skydiveD30571
Got my depth micrometer in the mail today. I found the D measurement of the old top cover to be .6155" and the new cover to be .616". Not sure of the specified tolerance range but it seems like the original shimming should be fine.
Don S
Should be fine with the old shims. You were lucky. I have found them .010 from old to new.
