Re: switching toons
The toons themselves are the same shape. The mounting brackets on top (to mount the toon to the under-deck bracing) may be different. Also, there may be different brackets welded to the rear cap for things like tansducers, aerator pumps, ladder mounts, etc. If none of this affects you (or you can work around it) the tube can be swapped left for right.
Todd
