As you may know, the hoses that feed the manifolds on a Mercruiser come from the thermostat housing (hot water from engine), and the hoses that feed the exhaust elbows come from a "bypass" that is part of the thermostat housing but is completely separate from the thermostat water flow, and receive their water flow from the raw water hose off of the water pump (always cold water).
I am wondering what happens if I swap the hoses around, so that the raw water goes into the manifolds and the hot engine water goes into the exhaust elbows. Will that cause problems?
I ask this because I am dealing with an overheat problem that I suspect has something to do with the manifolds having restricted flow. Last year is was really bad, so bad that I blew a split in a manifold hose while doing WOT on the lake. I replaced the elbows with new Aqua Power elbows and the problem has diminished, but the engine still wants to overheat at idle. Once I get to about 1800 RPMs the temp will drop back to 160, if it is above that while idling.
Considering that, I was thinking about swapping the hoses so that the water coming out of the engine goes though the new elbows only, which have no flow restrictions, and let the "bypass", cold water, go through the restricted-flow manifolds.
Now, I replaced the manifolds last night with a good set I bought from a fellow who had to change his exhaust type because of the cam he put into his engine, but I am wondering in case that doesn't work, and theoretically.
Thanks,
Chris
Thanks,
Chris
