Frank - If you are getting the same speed at a lower RPM, why up your RPM's to attain the same speed? You are burning more fuel at the higher RPM. I went from a 13 pitch to an 11 to gain RPMs to manufacture's specs. Got the RPMs but lost the speed. Cruising had to use more fuel to maintain the same speed. Probably going back to a 13.
What Frank is telling you that the Ballistic grabs more water per rev. It is "loading up" more than the other prop and pulling his rpms down. Loading a 4 stroker causes the vacuum to drop and change the timing to more advanced to pull the engine harder......tries to get the rpms back. This causes the ignition point to be earlier in the cycle and does burn more fuel since firing takes place too long before TDC where the piston can reverse and go into the power stroke.
Ever notice a colored vacuum gauge with the 3 color scales, used for determining best driving condition for max fuel economy: Red for low vac, engine lugging, excess fuel consumption, yellow mid range, green which is like driving down a hill, engine loafing vac rises and timing retards and fuel consumption drops.
Backing off the pitch aka "grabbing LESS water per rev" puts the vac in the green and raises the rpms toward max rated. Besides you get the best hole shot and water toy towing ability as a bonus.
