I have a Mercury 50 hp EF1 4-strokes 2012, recently change out the battery.
I hooked battery leads up to reverse poles.
Some fuses blow up
20 amp 25 and 15
All is replayced ,but when I try to start engine the 15 amp fuse blows again.
When I turn the key with ok fuses to test mode ( start) It beeps once and everything seams to work.
The smart craft shows data, and also tilt is working on engine.
But when I turn the key to run ,the fuse blows.
I have seen some post allready here So I have tried to do some search by my self.
I cant find any damage cables on motor or the control.
I found a vid on youtube https://www.youtube.com/watch?v=HXvq4gfVfsY
That seamed to have the same issue.
He swapped the cable asy diode and that was the fix. Dont know if this is gonna help me.
I have taken this harnes out and trying to figure out if i can do some measurement .
However dont know if I´m doing this correct
Shouldent one dircection give me some less figurers
Now they are simular.
Some fuses blow up
20 amp 25 and 15
