switch wiring problem
ander
Hi people<br /> Ima new owner of'79 searay overniter,one of several problems is that cabin lights, nav. lights or bilge pump , windshield wiper will only operate is if blower switch is on, and blower will not operate at all. Is blower switch bad, or is wiring all messed up?
petryshyn
Re: switch wiring problem
rule number one<br />>when things act weird......check the grounds!!!!!!<br /><br />>if check OK, then we'll proceed
dick
schematic is right check the grounds.<br />Aren't you the same guy replacing the engine?
SeaRay245
i had the same problem when i bought my 86 searay245 walkaround i think they hit it right on the head with the bad ground thats what was wrong with mine good luck
