Re: Switch to diesel???
Caldean.. Couple questions you need to ask yourself are, "how much am I going to actually use the boat, and how many hours do I plan on putting on the engines"... <br /><br />If you plan to cruise alot or make trips to the islands like Florida to the Bahamas, then diesels would be a better choice for both fuel economy and longevity... <br /><br />To convert to diesel there are other considerations than just the engines and gears... The propshafts will likely have to be changed out in leiu of larger diameter shafts... New props, couplers, cutlass bearings, struts, ect., are just a few things that have to be changed out... Lots of $$$$$...<br /><br />If you plan to "park it" and use it for occasional entertainment I'd stick with what it has... It would'nt be worth it to have the diesels and just have them sitting...<br /><br />Rebuilt 454 (assuming it has 454's) long blocks are about $3000 each... New 454, $7000 or better...<br /><br />Small Diesel, new, at least $20,000, probably more.... Used/Rebuilt, I dunno $$$ ?
