Switch box/powerpack
talbee
I'm getting a new Switch box/powerpack for my 78 Mercury 90hp outboard. Do I need to adjust anything on it before or after I install it?
GA_Boater
As far as I know, it's plug and play. No adjustments in the box or any needed.
Chris1956
As long as you do not adjust any of the timing screws (3 on plate above distributor) or the idle timing collar, or the distributor drive belt, you should not need to retime the motor.
talbee
Thanks everyone for your answers. I'm kinda redoing almost everything on this engine and the last part is this switch box
