Re: swing keels
I don't know your boat, but swing keels are generally raised by a piece of wire or possibly rope connected to some sort of winch. <br /> You'll have to figure out how the pennant(wire) is attached to the keel. <br /> Sometimes the wire is looped through a hole in the centerboard or a swaged on fitting attaches to the centerboard. <br /> Usually the only was to access the centerboard is to lower it. On a 26 footer you'll probably have to put the boat on stands to lower it.<br /> Be carefull the swing keel probably weighs 300 or 400 lbs.<br /> It might be a job for a boatyard. They should have the equipment to do it safely.<br /> While the board is being fixed, you might also want to check out the pivot pin, any gaskets at the pin, hoses that attach to a through hull that the pennant travels through.(The hose ends above the waterline for obvious reasons)
