Re: Swing keel clunking
I'm a C-22 owner as well, and yes, we do have issues with our swing keels. The hole in the cast steel keel will wear oblong over time, apparently from mooring with the keel in the down position (other owners say it doesn't matter- up or down). Anyway, the pin is marine brass and the brass castings that attach it to the hull will wear as well. In the C-22 community, it is pretty well agreed that a keel that is "thumping" is pretty darned loose, and needs to be fixed, soon. The repair is to remove the 550 pound keel, have the hole bored out to accept a press fit bushing, and replace the pin and castings at the same time. Also, replace the winch cable and volcano turning ball at the other end. While you have the keel out doing this stuff, go ahead and add the inserts mentioned by others to keep the pin/bushing from wearing as bad by taking up the "slack" when the keel is down.
For more info, go to chipford.com and check out his website. There is an amazing bunch of advice there, and he has done most of it.
