Swing away tongue ?
PAkev
My new rig is ordered and dealer advises that when the boat is on the trailer everthing will measure about 24 ft from coast to coast. However my garage is about 6 inches better than 24 ft and I would like to have a few more bonus inches to walk around the boat. I also need to be able to get my tractor out in the winter to plow snow. I could angle the boat in the garage but would anticipate loosing a lot of useful space by doing this. I am considering a swing away tongue which will give me about 18" to 2ft. extra room but have a few questions and concerns:<br /><br />Does the swing away tongue result in any additional sway when towing and can sway controls be used with swing tongues if I wish to put one on?<br />Does it require any more maintenance than a conventional fixed tongue?<br />Is it just as safe to tow as a conventional fixed tongue?<br />Are there any other advantages or disadvantages to help influence my decision?<br /><br />I looked at a swing tongue set up outside their showroom and it seemed to lock up relatively solid. I'm just not sure if I will have to make any compromises if I decide to go the swing away tongue route.<br />The dealer indicates there is no upcharge for the swing tongue which will be on a Caravan tandem bunk trailer. The fixed tongue alternative would be a Load Rite tandem bunk trailer. Both trailers would be rigged with surge brakes on all four wheels with a brake flush kit. The boat is a 19'11" polar center console weighing in around 2600 lbs with motor. I am pulling it with a Chev. 2500 Silverado w/Duramax Diesel.<br /><br />Helpful advice appreciated<br />Kevin
Re: Swing away tongue ?
"Does the swing away tongue result in any additional sway when towing " <br />No, It's Rigid.....<br /><br /> "can sway controls be used with swing tongues if I wish to put one on?" <br />Don't Know... Depends on Whose Controls...<br />You Really Shouldn't Need Any....<br />Sway is Usually caused by Impropper Set-Up....<br /><br /> "Does it require any more maintenance than a conventional fixed tongue?" <br />Other than a drop of oil now + then.... No...<br /><br /> "Is it just as save to tow as a conventional fixed tongue?" <br />YES....<br /><br /> "Are there any other advantages or disadvantages to help influence my decision?" <br />None I can see... For the Same Money..?? Go For It......<br /><br />Your 3/4 ton Chevy will Never Know your boat is Even There.........
PAkev
Thanks Bondo,<br /><br />BTW, I hope to cristen my new boat with a little road trip up to Clayton next year to fetch a few northerns after ice out. We usually camp at Cedar Point or Grassy Point but we sold the camper to buy the boat and will now be looking for a cottage or cabin to rent on our trips to the 1000 islands.<br /><br />Kevin
OK Kevin,<br /><br />I've done Alot of paving for Many of the Cabin/Motels in the Clayton area.... If you'd like, I could give you some phone#s for a few of them....<br /><br />Depending on Exactly When you're coming up, Maybe I'll be Fishing in those waters.... Thou I spend Most of my Early season fishing in the Big Lake.....<br /><br />I'm heading out this afternoon, on the River, to Try in Hunt down some Muskies......
