Swapping OceanPro Powerheads
I lost compression on my 1993 Evinrude ocean pro 200hp last weekend. I accidently ran it out of 2 stroke oil. I found a 200 Johnson ocean pro for a good price but it looks like crap and the lower unit and trim is shot. My 93 looks great and the trim unit works well. I'm wondering if i can just pull the powerhead off the 1993 and replace it with the 2000 Johnson. Will it bolt up with no issues? Will the existing harness and other wires connect without issues? If there are any issues would it be because of the difference in the year or because one is a Johnson and one is an Evinrude.
Attachments​
Thanks again Fazt.
Could I strip everything off my 93 Evinrude ad put on the Johnson? Just swapping powerhead keeping everything else from old motor.
Thanks for your help Faztbullet. I have pulled the powerheads off both motors and decided to keep the new motor intact and just use the wire harness adapter you suggested. Super simple to install. It never dawned on me that I would need a new gasket from mid-section to powerhead. Gotta wait a few days to receive it before i can reassemble. What's your thoughts on using sealant or installing the gasket dry? Thanks again.
