JasonAChastain
- Nov 17, 2005
- 2
I have a 1990 90 H.P. Nissan motor that was working fine on our first day of a fishing trip then when i started it on the second day it was like it had lost half the power. A compression test showed a weird fluctuation between the 2nd and 3rd cylinder. I've tried a new head gasket, changing the coil packs around, rebuilding the carbs, then a new CDI box but with no help. I've heard of a gasket on the bottom of the cylinder around the crankshaftthat could go bad but my manual only shows some sort of "compression ring" (i guess like a piston ring?)on the crankshaft between each of the cylinders. Any help would be appreciated. <br /> Thanks
