Swapping 125 for 120
Pjrogu
Hey all, I’m looking to put a 1997 120 in place of my 125. Does anyone know if the steering and throttle cable lengths/position is the same. Also, is the power trim unit the same because the 120 has a busted trim but my 125 is fine. Thanks!
jerryjerry05
The cables are probably the same length but the cables are
probably different??
The 97 used Mercury connectors/cables and shifter.
The 125 used Force/Chrysler cable ends and shifters.
They use different wire harnesses too.
roscoe
And power trim unit is completely different , as is the mid section it bolts on to.
