Ok hopefully someone has done this before. I was told this is a direct bolt-in. And it was sort-of.
The motor mounts in the same postion but the manifolds are offset 1" wider than the Y pipe. Is there a offset bellows to fix?
The engine runs great (water running thru openings) dont have outdrive on yet just running hose to intake line inside boat.
The boat that I took this engine out of is a 77 SeaRay that had a 3 inch Y pipe that I gave to a friend. I can get it back but I dont want to pull engine again.
