Hello everyone.
Well, it ends with a total replacement of the engine.
The current engine is a Volvo Penta 5.0 GL-B V8 GM, 2 barrel carburetor, 1 electric fuel pump.
Replacement engine, is a Chevrolet Performance 350 / 5.7 V8 Vortec.
The problem is that the camshaft must probably be replaced, with regard to the back pressure in the exhaust.
But the question then is whether the cam from 5.0 (the current engine) will fit in the new engine? I think they do, but am a little in doubt.
Info about the new engine:
Power-cyl. heads with 1.94 in. intake valves and 1.50 in. Exhausts, and 64cc combustion chambers that yield a 9.4: 1 compression ratio. This combination is paired up with a roller cam that has 0.414 in. of intake lift and 0.428 in. for the exhausts. Duration at 0.050 in. of lift is 191 degrees for the intakes and 196 for the exhausts, with 111 degrees of lobe separation.
So what do you think about it, will it be an option or should we grab another bump?
Of course, frost plugs etc. must also be replaced, but it is now mostly the cam we are struggling with.
Thanks
Thanks
