I swamped my boat last Saturday.  Forgot the pesky plug.  Water got to 1 inch below the top of the crank case.  Oil in motor is ok and not milky.  Oil in Power Trim is milky.  I have tried to bleed the oil and water by cycling the sterndrive up and down completely numerous times, but I have now gone through over 5 qts of oil.  I apparently don't know what i am doing because i have made a huge mess trying to change this oil.  By the way, the trim system works fine in all positions.  (I am a newbie do it yourself'er)
I now notice a little surface rust on block and a few electrical connections on alternator. Boat turned over perfectly after I got the water out.
1. Can someone provide advice on what I need to do to remain worry free?
2. How do you properly change the oil in the power trim?
3. Should I worry about the starter going bad in the future (I swamped this boat 5 yrs ago during a thunderstorm and I'm pretty sure water got above the starter. Have had no issues since).
4. Marine Mechanic told me that I'd get anode problems now all over any electrical connection. How's that? The water is gone. I pulled a few plug wires and everything looks perfect.
5. Anything else that I am leaving out?
Thanks for your help.
