Suzuki
RAYCRAFT
Hey Guys, I'm a newcomer to the site, glad to be here. I'm having a problem with my 93 Suzuki 115. When I hit the throttle to get up on plane it just kind of lags. If somebody sits at the bow it eventually breaks over and seems to run very close to normal. Engine warm or cold, doesn't matter. The boat(93 Raycraft fish&ski) did sit up for a while, probably 1yr. I put in fresh gas. All suggestions will be greatly appreciated........RAYCRAFT
D
DJ
Guest
Re: Suzuki
Raycraft,<br /><br />With the boat in the water, this won't work on muffs.<br /><br />Disconnect one spark plug wire at a time and see which cylinders are not pulling their load.<br /><br />I'll bet you have some clogged carbs.<br /><br />I had a Suzy 140 (DT-140) that is basically the same engine. It had the most sensative carbs. I have ever seen.
