nightcrawler
- May 28, 2001
- 3
SUZUKI WARRANTY PROBLEMS
I have a 1998 200 h.p. suzuki. The water pressure valve did not seat compleatly causing the #5 piston to lock up, pulled the connecting rod from the piston then the rod busted a hole in the piston. Suzuki says it is not covered in the third year of the warranty even though the motor has only 122 hours on it. Has this happened to you? Please reply
