Suzuki Props
snard
I have two Stainless Props previously used on a Suzuki 200. I no longer own the Suzuk and I am currently running a Johnson 225. Is there any way that the hubs can be replaced so that I can use these props on my Johnson? If not, does anyone know where I could sell these?
suzukidave
Re: Suzuki Props
Don't know the answer but it may be possible. My Suzuki 55 has a Mercury prop on it that was switched to a suzuki hub by the disributor to fill my order after they got back-ordered by the factory for six months on suzuki props. I checked this board before agreeing to this and was told a good prop shop can change compatible hubs between brands and balance it no problem --remember the inner hub is totally suspended in rubber. So far the prop works fine and I would never have known if they hadn't told me.<br /><br />Before you call your dealer though, two questions?, are the diameter/pitch of these props compatible with the Johnny? Second, what about the diameter of the rear sleeve on the outer hub that slides into the lower unit?
