I've got a 70 hp 4 stroke Suzuki and have a 13 1/4 x 17 pitch U series prop. I just purchased a identical size and pitch V series prop. Both fit exactly the same on the prop shaft and spacing is the same. The V-series hub it pressed in from behind and the U-series from the front. The exhaust flange is a bit difference (flared on the V-series). Should I expect any difference in performance? Why the change? I haven't tried the new prop out yet.
