Suzuki DT90 shuts off
dougsmp
The motor runs fine but cranks and runs for a few seconds and then shuts off, may even start back up before it stops rotating. Unpluged the throttle position sensor, the grey wire from the switch to the motor, or the moniter and the motor will continue to run but will not get up on a plain. I have replaced the sensor but still have the same problem. :confused:
jim dozier
Re: Suzuki DT90 shuts off
Need more info on the history of this engine and problem.
dougsmp
engine will not idle below 2500 rpm with the CDI unit plugged in but will idle fine without it. I am thinking the CDI unit is bad but there is no one in my area that can test it. I would also like to know if anyony has a used on for sale.
mrn714
Did you check the carb flow?
