Will the bottom unit fluid replacement hole accept a Lubrimatic screw in to replace fluids or does Suzuki's require a different fitting? Also on my Suzuki DT75 theres two screws on the upper bottom unit. One says oil drain. I have not seen those on the Johnson and Evinrude engines. Was wondering if replacing the fluid in the lower unit was different on Suzuki's?
