Hello, I have a 1985 Suzuki dt65. The oil injection does not work properly. The oil only pumps to the impulse ports/check valves on the crank case, but not past. Today, I removed the hoses from where the connect to the intake and filled them with oil. The top cylinder hose held oil, but the #2 just drained into the crank case through the impulse port/check valve. I can’t remember what the bottom cylinder hose did. I also re-bled the pump (only one tiny bubble seemed to come out).
Question #1. Are the check valves/impulse ports replaceable? They come right out of my 1987 parts motor with a firm wiggle and pull. But the 1985 valves are round (hard to grip) and seem to be in tight enough I can’t remove them without destroying them.
Question #2 is there a name for the check valves/impulse ports on the crank case? Where can I get replacements?
Question #3 if the one crank case impulse valve is malfunctioning that bad, would it absorb all the pump pressure and reduce the pressure on the other two lines?
thanks in advance!
thanks in advance!
