Suzuki DT30 1988 Carb float height.
Status
Not open for further replies.
James R
Hi.
Cannot find the height chart in my Seloc. Can anyone tell me what the float height setting should be?
Thanks.
Jim.
dsinger
Re: Suzuki DT30 1988 Carb float height.
I set mine level with it held up side down. Now that might be wrong since I am new to Suzuki but on the American ones that is how I do it. I am sure there are several people on here that can set you up.
grid
That works just fine. Make sure the float tang just barely touches the needle, and doesn't compress the spring inside the needle.
James R
Thanks for the info guys.
I was hoping someone could give me the actual setting in mm but for the moment Iwill go with what you gave me.
Thanks again.
Jim.
GA_Boater
Not bad - Answering an eight year old thread. Closed.
Status
