Re: Suzuki DT25 Not cooling
These used to drive us nuts, and the only way to cure it is to remove the powerhead. Once that is off, you will see 2 holes which dump water into the trunk, to keep the megaphone area of the trunk cool. The holes are about 5-6mm. Block one of them up, prefably by welding, but I used an alloy filler for the first couple, as I was unsure if it would work, and the problem goes away. I was skeptical at first, but eventually Suzuki brought out a service bulletin, which said the same thing as we had been doing. As you were saying, it is a very frustrating problem, and we have traded motors in for a fraction of their real value, because the owners have had them to 4 or 5 shops, and messed around with them, until they are thoroughly sick of them, when the repair is actually a quite easy fix, takes about 1 or 2 hours. Let us know how you go<br /><br />Regards, Paul
