Re: Suzuki DT25 Mod's
nothing was wrong but I was just trying to think ahead.
That about covers it all. I've never understood the point of leaving parts away that could (could that is) cause future problems. All these parts are there for a reason (Engineers have been developing it from scratch).
Some features might look cheap and are absolutely pointless (some actually are but that is another discussion) at first but when looked at closer they perfectly make sense.
"mods" are only as good as the theory behind them and the people that practice them. Leaving parts away is not something I associate with "modifiing". The keyquestion to me is : will it improve the overall performance of the engine after modifiing? Ofcourse one could say that leaving parts away does improve performance when it comes to "power to weight ratio" (No argument there because that's a fact).
referring to the question above, leaving the airfilter (dustbox or wathever) away could actually decrease overall performance. The Carb needs a forced airflow to operate so needlevalve settings will have to be adjusted. You could allready run into some problems there making new adjustments. It was stated here above, water might get into the carb or even worse dust.
The remark of riverrunner is also an option..... Buy another engine from brand X if it the one from brand Y gives you trouble. Hardly an option unless one's a miljonair (no offence). I own 2 Suzuki DT's (4 and 65). They do the job perfectly. People tend to "blame the engine" for malfunctioning and somethimes they are right. some, however forget to tell the whole story behind the malfunction when sending a curse on a certain brand. (obviously they all stop running if you don't put oil in the cranckcase..
It happens, no kidding!)
Modifiing is a fancy word and it looks cool if you can master it or know what you are doing and it can make your engine run smoother and give you better overall performance. If not you might be taking "the long way home" eliminating "future problems".
my 2 cents
Stevo
