Hi I hope someone can help I have a DT25 1984 model which is not throttling properly in or out of gear makes the plugs oily and dribbles oil from the exhaust port.
I have tried cleaning carb, replacing plugs (resistive type), checking fuel pump and fuel filter, have the mixture valve 1 1/2 turns out from fully in (soft position), all of which have had no effect.
There is combustion pressure when pull start is pulled which feels pretty even but I have not measured this.
The engine will tick over and will run but feels bogged down like it is misfiring.
Any help would be appreciated
